Elite Series Upgrades & Add-Ons
Available Options
Contact our sales office for pricing details.
Power Packages & Add-Ons
Lithium Platinum Package
- 640 AH Lithium Batteries
- 400 Watt Solar Package with Victron Charge Controller
- 3000 Watt Pro Inverter
Lithium Pro Package
- 260 AH Lithium Batteries
- 240 Watt Solar Package with Victron Charge Controller
- 2000 Watt Pro Inverter
- 390 AH Lithium Batteries
Solar Pro Package
- Two (2) 6V AGM Batteries
- 2000 Watt Inverter
- Four (4) AGM Batteries
Start Your Adventure Today
30 Amp Convenience Connection
Add a female plug to the front of the RV trailer that allows you to conveniently power your RV trailer no matter the location of the closest source.
Other Upgrade & Add-on Packages
Electronics Pro Package
The Electronics Pro Package is a cost saving package of some our most popular add-ons that includes...
- 4G Cell Phone Booster
- Electronic Door Handle/Lock
- Wireless Backup Camera with LCD Display
- Auto Drain Electric Backflow Preventer (not included on Legacy Elite package)
Outdoor Pro Package
The Outdoor Pro Package is a cost saving package of some our most popular add-ons that includes...
- Front & Rear Propane Quick Connects
- Aluminum Storage Basket
- 1.25" Rear Bumper Receiver
- Additional 30 AMP Convenience Connection
- 30 LB Propane Tanks Upgrade (not included on Legacy Elite package)
Technology Options
Portable Satellite TV Antenna
Easily connect to DIRECTV & DISH NETWORK. Includes a Portable Tripod.
Omni-Directional Antenna
Compact amplified Omni-directional antenna continuously receives VHF/UHF/FM signals from all directions without adjustment.
Digital Wireless Back Up Camera
The backup camera package includes a 4.3 LCD color monitor with integrated receiver, one 12-volt accessory plug, a suction cup monitor mount, one rear color camera with integrated transmitter, stainless steel hardware, and non-corrosive camera mounting bracket and speaker. This allows you to see other vehicles behind you while driving and assists you when backing up.
The cell phone booster for vehicles extends cellular signal range to ensure you get better voice and data with fewer dropped calls, improved voice quality, faster uploads, and downloads.
This booster is compatible with all US and Canadian wireless networks such as Verizon, AT&T, Sprint, T-Mobile, US Cellular, Straight Talk and more.
Interior Options
Nature’s Head Composting Toilet
Replaces the standard Dometic toilet. The toilet is self-contained, urine diverting and the waterless operation allows for ease of use for many applications. The Nature’s Head is lightweight, odorless and compact making it a perfect fit for your Ollie. The toilet with its stainless steel hardware, robust construction, and user-friendliness has been designed to withstand the harshest of conditions.
Couch Bed Extra Cushions
Add an extra couch bed cushion to increase comfort and flexibility.
High Quality
Foam Mattresses
Need an even better night's sleep while you're on the road? Upgrade to a comfortable foam mattress which will serve as a replacement cushion for any of your needs.
*Available on Standard and Twin Bed Floor Plan
Hypervent Condensation Prevention Matting
Plain and simple, a differential between the inside and outside temperature can cause condensation. A favorite place for condensation is under mattresses, bunk pads and cushions. Ask any boater and they'll tell you stories of damage caused by condensation.
HyperVent is the most practical solution for the prevention of dampness (condensation) forming beneath beds. Before HyperVent, the approach to dealing with dampness and the resulting mold (odor) was to accept the problem as inevitable and to treat the symptoms. The most common treatment was simply drying the bedding.
Cabinet Under Twin Bed Nightstand
Add a cabinet under the nightstand to provide extra storage capacity. Available only on the Legacy Elite II Twin Bed Floor plan.
*Not compatible with add-on Lagun Table.
Stainless Steel Convection Microwave
With the RV Stainless Steel Convection Microwave you can now bake, brown or crisp foods using the convection function, or the combination convection and microwave oven. This RV Stainless Steel Convection Microwave has the cooking power and additional heat settings that allow you to cook just about any food you want.
*Replaces the standard microwave.
Automatic Backflow Prevention Valve
Push-button convenience prevents backflow between greywater and shower.
Shower Curtain Track
Want to keep your wet bath dry? Add a shower curtain track to your bathroom and shower and personalize it with your own choice of a shower curtain.
Propane Options
30LB Propane Tank Upgrade
How would you like to make fewer trips to refill your propane tanks? Increase the standard 20 lb. tanks with the upgraded 30 lb. tanks and increase capacity by 50%.
To truly enjoy your outdoor experiences, consider adding front and rear trailer connections used for grills, torches, and propane campfires.
Water Heater & Ac Options
Truma AquaGo® Comfort On Demand Water Heater & Truma Aventa Eco AC
The Truma AguaGo Comfort is an on-demand water heater that allows you the most efficent hot water usage. The Truma Aventa Eco is one of the quietest non-ducted air conditioning units available in the RV industry. Independent studies have shown it to be up to 30 decibels quieter than the Dometic Penguin II.
Truma AquaGo® Electric Antifreeze Kit
The Truma Electric Antifreeze Kit keeps the Truma AquaGo™ instant water heater frost-free to -4 °F (-20 °C) while you are driving or if there is no gas supply. To operate the Truma antifreeze kit you need a 12 V (minimum 120 W recommended) power supply from the on-board system. The Truma electric antifreeze kit protects only the water in the Truma AquaGo instant water heater against freezing. The Truma electric antifreeze kit will not protect the Oliver’s entire water system. Water lines, faucets, water tanks and the external water valves and the vehicle must be heated separately.
Micro-Air Easy Start
This soft start capacitor allows you to start and run your A/C with a generator. Contact us for more information on generator requirements. Only available on Dometic Penguin II AC units.
Exterior Options
Adds a rear-end receiver. Useful for a bike rack or other. There is an RV Approved bike rack from Lets Go Aero BikeWing 1.25" that you can order from a 3rd party vendor.
Storage Basket
Adds a storage basket on the front, used for transporting *Generators or other camping accessories.*Never operate a portable generator in this basket. Check with your generator's manufacturer to determine a safe operating distance.
Additional Awning
Want more shade? Consider adding another Awning to the street side of the trailer.
Door Handle/Lock with Electronic Keypad
Upgrade the standard door handle/lock with the option to lock and unlock the door with a user-friendly electric keypad.
Dealer Upgrades & Add-Ons
2-5/16" Bulldog Coupler
Andersen “No-Sway” Hitch
New Anti-Sway, Anti-Bounce Weight Distribution Hitch has completely redesigned weight distribution for a safer and more secure towing experience.
Also available for 2-5/16" Bulldog Coupler
Cradlepoint Wireless WAN
Cradlepoint wireless edge solutions unlock the power of LTE and cellular networks to give your WAN the boundless reach, nonstop reliability, and real-time agility it needs to keep up when you need it the most. The Cradlepoint IBR900-120B router is paired with a roof mounted omni-directional Taoglas MA1506.AK.001 Antenna to give you superior connectivity on the go.
- Work Remotely
- LTE Capability
- Streaming Capability
- Connect to Local WiFi
- Data Plan Accessibility/Choose Carrier
- Connectivity Inside/Outside of the Trailer
- WiFi Calling Capability
- Stay in Contact with Family and Friends
A cellular data plan is required. Contact us for current data plan rates.
Calmark Cover
Protect your Oliver Travel Trailer with a custom cover by Calmark.
Portable Solar Panels
230-Watt Portable Panels
LP Quick Connect Accessories Package
- Weber Traveler Portable Grill (Quick Connect Ready)
- 19" LP Fire Pit with Hose & Cover
Outdoor Party Package
- Two (2) Oliver Chairs
- 8' x 16' Outdoor Mat
- Clam Venture Shelter
Outdoor Leisure Package
BMPro ProSmart Packages
Expandable system that allows you to monitor up to 40 Bluetooth sensors on your mobile app. Packages include...
- LP Tank Smartsense sensors for each tank
- TPMS Smart Pressure sensors
- Temperature sensors
- LP Tank Lock Kit - helps prevent LP tanks theft
