Compare Models
Elite vs Elite II Comparison
We put together a comprehensive comparison on the latest Oliver Fiberglass Travel Trailers!
Hull |
Legacy Elite |
Legacy Elite II |
Body |
Four-piece molded fiberglass with insulation between shells | Four-piece molded fiberglass with insulation between shells |
Insulation |
Double Hull, Thermal Break with Insulated Double-Sided Radiant Barrier Polyethylene Bubble + Radiant barrier + Vapor Barrier + Air Gap Barrier. | Double Hull, Thermal Break with Insulated Double-Sided Radiant Barrier Polyethylene Bubble + Radiant barrier + Vapor Barrier + Air Gap Barrier. |
Floor Plans |
Standard (74" x 52" Bed) | Standard (75" x 79" Bed) or Two 75" x 30" Twin Beds |
Exterior Length |
18' 5" | 23' 6" |
Exterior Height - Top of the A/C |
9' | 9' 7" |
Exterior Width |
6' 6" | 7' |
Interior Height |
6' 1" | 6' 6" |
Interior Width |
6' 2" | 6' 7" |
Dry Weight (Base) |
3,700 lbs. | 4,900 lbs. |
GVWR |
5,000 lbs. | 7,000 lbs. |
Net Carrying Capacity |
1,300 lbs. | 2,100 lbs. |
Fresh Water Tank Capacity |
Design Capacity 32 Gal. | Design Capacity 32 Gal. |
Grey Tank Capacity |
Black Tank Capacity |
Design Capacity 15 Gal. | Design Capacity 15 Gal. |
Furnace, Water Heater, & A/C Package |
Standard Package Includes - Truma VarioHeat Furnace, Suburban Water Heater, and Dometic A/C Optional Upgrade Package Includes - Truma VarioHeat Furnace, Truma AquaGo® Comfort Tankless Water Heater, & Truma Aventa A/C |
Chassis |
Legacy Elite |
Legacy Elite II |
Axles |
Dual Shocks on Single 5,200 Lb. Dexter "Nev-R-Lube" Leaf Spring Axle | Quad Shocks on Tandem 3,500 Lb. Dexter "Nev-R-Lube" Leaf Spring Axles |
Brakes |
“Nev-R-Adjust” 12″ electric brakes for exceptional control and braking (Now with Bronze Bushings and Grease Zerks) | "Nev-R-Adjust®" 10" Electric Brakes |
Front Tongue Jack |
Electric Powered | Electric Powered |
Stabilizer Jacks |
Electric Powered x2 | Electric Powered x2 |
Wheels |
Premium Aluminum Rims with 10-ply Tires w/Black “Rock Guard” Wheel Well Lining | Premium Aluminum Rims with 10-ply Tires w/Black “Rock Guard” Wheel Well Lining |
Spare Tire |
Full Size Spare with Aluminum Rim | Full Size Spare with Aluminum Rim |
Hitch Connection |
7,000 Lb. Cast Iron Bulldog Hitch (2") | 7,000 Lb. Cast Iron Bulldog Hitch (2") |
Frame |
2" x 5" Box Tube Aluminum Frame | 2" x 5" Box Tube Aluminum Frame |
Rear Bumper |
Hide-Away Brushed Aluminum Storage Bumper with Black/Grey Water Drain Hose | Hide-Away Brushed Aluminum Storage Bumper with Black/Grey Water Drain Hose |
Exterior |
Legacy Elite |
Legacy Elite II |
Exterior LP Gas Port |
Exterior Quick Connect Ports available for Front and Rear (Option) | Exterior Quick Connect Ports available for Front and Rear (Option) |
Outside Wash Station |
Standard | Standard |
Battery Storage |
Custom Enclosed Slide-Out Battery Storage (Fits Up to 2x Batteries) | Custom Enclosed Slide-Out Battery Storage (Fits up to 4x batteries) |
Deep Cycle Batteries |
2x 12 V Batteries. Optional 6V AGM Batteries and 12V Lithium Batteries are Available. | 4x Group 27 Deep Cycle 12V Batteries. Optional 6V AGM Batteries and 12V Lithium Batteries are Available. |
Propane Gas Tanks |
20 lb. x2 LP Tanks | 20 lb. x2 LP Tanks (30 lb. Upgrade Available) |
Exterior Lighting |
High Mount LED Porch Lights, LED Ground Lights, LED Rear Brake and Backup Lights. Custom Rear High Mount LED Oliver Sign. | High Mount LED Porch Lights, LED Ground Lights, LED Rear Brake and Backup Lights. Custom Rear High Mount LED Oliver Sign. |
Awning |
Powered Girard Awning with Wind Sensor & LED Light Strip. | Powered Girard Awning with Wind Sensor & LED Light Strip. (Option for Additional Awning on Street Side) |
Windows |
3x Sliding Thermal Pane Windows with Sliding Screens and Rear Emergency Egress Window | 4x Sliding Thermal Pane Windows with Sliding Screens and Larger Rear Emergency Egress Window |
Steps |
Fold Up Aluminum Double Entry Steps with Grip Tape | Fold Up Aluminum Double Entry Steps with Grip Tape |
Interior |
Legacy Elite |
Legacy Elite II |
Interior Lighting |
LED Lights | LED Lights |
Window Shades |
Day/Night Window Treatments (Excludes Bathroom) | Day/Night Window Treatments (Excludes Bathroom) |
Digital Monitoring Systems |
Wall Mounted, See Level II Monitoring System for Tanks and Battery Voltage | Wall Mounted, See Level II Monitoring System for Tanks and Battery Voltage |
Vent Fan |
Maxxair Fan Deluxe RV Ventilator System with Remote Control | Maxxair Fan Deluxe RV Ventilator System with Remote Control |
Floor Construction |
Gel-coat Over Fiberglass Molded Inner Shell | Gel-coat Over Fiberglass Molded Inner Shell |
Interior Wall Construction |
Decor Packages |
Decor Packages that include Fiber-Granite Countertops, Premium Vinyl Flooring, and Cloth Uphostery on Cushion (Options available for Upraded PU Leather on Cushions and Memory Foam Mattresses) | Decor Packages that include Fiber-Granite Countertops, Premium Vinyl Flooring, and Cloth Uphostery on Cushion (Options available for Upraded PU Leather on Cushions and Memory Foam Mattresses) |
Electric |
Legacy Elite |
Legacy Elite II |
12V USB Charging Outlets |
12V USB Charge Station | 12V USB Charge Station |
Interior 120V Outlets |
120V Outlets on GFCI Protected Circuit | 120V Outlets on GFCI Protected Circuit |
Exterior 120V Outlets |
Battery Converter/Charger |
45 AMP Converter with Battery Charger | 45 AMP Converter with Battery Charger |
Solar Package |
Optional Integrated 240W Roof Mounted Solar Panel with Charge Controller | Optional Integrated 400W Roof Mounted Solar Panel with Charge Controller |
Inverter |
Option - 2000W Pro Inverter Available | Option - 2000W & 3000W Pro Inverters Available |
Power Cord |
30 Amp Power Cord | 30 Amp Power Cord |
Kitchen |
Legacy Elite |
Legacy Elite II |
Cooktop |
2-Burner LP Cooktop | 2-Burner LP Cooktop |
Refrigerator |
Isotherm 2-Way Refrigerator (12V, 120V) | Isotherm 2-Way Refrigerator (12V, 120V) |
Microwave |
Stainless Steel Microwave - Option Microwave Convection Oven | Stainless Steel Microwave - Option Convection Microwave Oven |
Cabinetry |
Acrylic Faces with Custom Designed Soft Close Storage Drawers with Dovetail Joints | Acrylic Faces with Custom Designed Soft Close Storage Drawers with Dovetail Joints |
Bathroom |
Legacy Elite |
Legacy Elite II |
Bath Type and Features |
Wet bath - Molded Vanity with Waterproof Toiletry Storage and Towel Bar, Chrome Faucet with Pull Out Shower Wand. (Option for Shower Track for Curtain) | Wet bath - Molded Vanity with Waterproof Toiletry Storage and Towel Bar, Chrome Faucet with Pull Out Shower Wand. (Option for Shower Track for Curtain) |
Toilet |
Low Profile Dometic 311 Toilet With Porcelain Bowl. (Option For Composting Toilet Is Available) | Low Profile Dometic 311 Toilet With Porcelain Bowl. (Option For Composting Toilet Is Available) |
Entertainment |
Legacy Elite |
Legacy Elite II |
TV |
120V 24" Flat Screen LCD TV (requires Inverter) | 120V 24" Flat Screen LCD TV (requires Inverter) |
DVD, AM/FM/CD Head Unit with Speakers |
AM/FM Radio, Bluetooth®, HDMI, DVD, MP3, and CD-R/ RW Playback with Custom Mounted Speakers x4 | AM/FM Radio, Bluetooth®, HDMI, DVD, MP3, and CD-R/ RW Playback with Custom Mounted Speakers x4 |
Cable/Satellite TV Hookup |
Cable/Satellite Ready with Extra Dual Exterior Coax for TV | Cable/Satellite Ready with Extra Dual Exterior Coax for TV |
Safety |
Legacy Elite |
Legacy Elite II |
Detector Alarms |
Fire Extinguisher, Carbon Monoxide, Smoke and LP Detectors | Fire Extinguisher, Carbon Monoxide, Smoke and LP Detectors |
Pricing |
Legacy Elite |
Legacy Elite II |
Starting Price |
$65,500 | $73,500 |
